Damaged Whammy IV Project
  • Damaged Whammy IV Project
    Hi Guys,
    I am a software engineer with some mild soldering skills and have decided to make a project out of fixing this broken Whammy my friend passed me.
    I know that the custom chips in these effectively makes them bricks if they are fried - but i am hoping its the power section.
    The pedal powers on and produces a Dry but no Wet Signal.
    I have documented my findings so far on Flickr.
    Damaged Digitech Whammy IV Circuit Board - a set on Flickr
    I am not an experienced fault finder but i have some equipment and am willing to read up on what i need to do.
    To start with - could someone take a look at the damaged underside of my board and maybe suggest if someone has already tried to fix it - or if the damage is heat damage?
    I am trying to find a schematic so i can tell what exactly components U1, C4 and C57 actually are....
    Thanks
    Kwikk
    Originally posted by kwikksilva View Post
    Hi Guys,
    I know thaed - but i am hoping its the power section.
    Thanks
    Kwikk
    C4 and C57 are electrolytic capacitors 10uF_16V of different types.
    U1 is the LD1117V33 fixed regulator 3.3V.
      Thanks Doctor! :-)
        Hi,
        I had the same problem except that when the whammy was not in the box it would work ok . I found that when the pcb was screwed in carefully and a spacer used it worked fine when put back together.
