changing .0068 caps in SMALL STONE
  • changing .0068 caps in SMALL STONE
    has anyone dabbled with this "uni-vibe" mod for an "older" '76 (NOT J-board) EH SMALL STONE pedal?...heh...I did it in my re-issue SMALL STONE, and now it fails to work...!I think that happened when I was popping the board back into place, the POT accidently bent in the cheezy "new junk type" 9 volt plug lobe...when I went to plug it into my pedal board, it just "crackled & failed"...so now I have my "original '76" SMALL STONE" and am a little weary to try this mod on it again...(the board layout ain't the same on the reissue)...geez...maybe someone could help me get that reissue working again :P... maybe its the 3dpt switch that went bad?
    here is the source link of that mod
    http://www.lynx.bc.ca/~jc/pedalsSmallStone.html
      Seems to me like you either got some solder where you shouldn't have, or else cracked the board.
