hi guys, ive been thinking of making myself a distortion pedal and was wondering if it was possible to use an actual tube to create the distortion (ie volume through the tube to get the right level of distortion, and then another pit after to get a suitable volume)
now, is this easy to do, or is doing this basically making a simple amp.
to overdrive the tube would i need a certain voltage, or do you overdrive the tube in another manner? (i think its the voltage, but thought id ask just incase)
if it is the voltage, is it possible to get a tube that is small enough to overdrive at low enough levels to use with a 9v battery or a similar thing (maybe a wall attachments to get the right power input) and is small enough that it can be then be toned down using a pot to a output level that isnt too much different from passive guitar pickups? (basically something that would work fine on my amp)
im not that knowledgeable about electronics, but ill look into it if it is possible.
thanks for any help
thanks for any help
