I recently did the true bypass mod with the blue 3PdT switch to a friend's TS that already had the LED replaced with a super bright blue one. Seems the combination of the two draws down the battery faster, and as an added bonus the super bright doesn't get dimmer, even down to 4 volts when the pedal sounds like poo. Friend wants the LED dimming feature back. Original one is gone. I want to put in a red one that will dim when the battery gets low, but I understand that the true bypass mod changes things a bit by removing the switching transistor and zener. What would be a good replacement LED for this that will not draw down too much, and will preserve the dimming feature?
Friend is a high end guitar player, and the most sensitive player I know with regards to his gear.
