schematic can be found here: BOSS AUTOWAH AW-2 Service Manual free download, schematics, eeprom, repair info for electronics
The symptom is the pedal is generating no effect. The pedal passes guitar signal in bypass and when engaged, though there is a 'tonal difference' between the two. None of the controls have any effect on the signal.
Can someone give me a hint on where to start with it?
I've got it out of its shell, and I'm assuming I will need to jumper the output jack's ground lug to a ground in the circuit since it doesn't have the shell to ground to...
Edit: After loosening and re-tightening the jack and pot mounting hardware, the unit does pass some effect. The effect doesn't seem as pronounced as it should be. The rate and depth controls seem to be working, but the "manual" and "sens" controls only seem to slightly alter a wee bit of treble.
