Hi Guys
Decided to buy a broken "Vox tonelab SE" for 50 quid thinking it was something simple to fix as there was no sound; Doh! Wrong!!!
I turned it on and all seemed OK all the led's lit up digital dispaly showed program number ect...... but there was no sound getting through the unit from my guitar although there was a hiss which audable from the output and could be attenuated by the volume control on the rear of the unit! OK I thought let's have a look inside for "hopefully" something loose! Wrong again! However I did find that one of the two DSP chips on the main PCB KLM2455(A) a Texas Instrument TMS57070FPJ was so hot that you couldn't keep your finger on it!
Now I know that this chip is now discontinued and there are no data sheets available either but it seems readily available from many different sources, however before I decide to buy one and have a go at soldering those tiny 100 little connections, I've never tried a heat gun!
I thought I should ask you guys a couple of questions: -
1: What do you think caused this chip to fry?
2: Could it be a problem with the power supply to the ic/ic's?
3: Could an overload on the input fry the chip?
4: Is this a common problem?
5: Is there a way to tell if other chips are affected?
6: And finally! Do you think it's worth fixing!
Regards and thank you in advance for any help or suggestions!
Lostfollicles
Lostfollicles
