Hello, folks. First post for me. I recently inherited a MXR M80 Bass DI that has no output signal. All of the led indicators function properly, the in & out jacks check out as no shorts or opens. 9v battery is good & appears to be putting pwr out to board. Voltage appears to be getting to all of the op amps. I say 'appears' as I'm not sure what the correct value should be. Same with the test point values. There are 15 tp's that I've found. TP VOM readings range mainly around 3.76 with a couple of zero readings.
I'm having a lot of issues as the only schematic I have to work off of is this:
MXR M80 Schematic
Not the clearest print for old eyes to work thru. I inadvertently draped my finger across the area of R94/C97 & did get output, albeit noisy. So I'm still conductive.
I also notice what I believe to be indications of a short between the top of the TLC2264 op amp & the back of the pot above it (divot in the chip/small flash mark on the pot).
Any suggestions on how to better isolate the issue than my simply ordering/replacing oa's? As you can tell, I do not play much at the component level. Any guidance will be greatly appreciated.
Archie
MXR M80 Schematic
Archie
