Guys!
I'm trying to troubleshoot a DL-4 I have.
The previous owner conected a 110v walwart into a 220v socket, and he had to rebobinate the primary. So he used it with batteries.
When he got the repaired transformer the the DL-4 wont turn on plugged.
I opened and the 1000uf capacitor C40 was blown, and the power section was making a faint buzz when plugged (???)
I replaced it and the buzz went out. But the pedal never started again, neither with AC or batteries.
I measured everything and it seems ok, only the out of the doubler is a bit "weak" measuring 6.06v instead of 6.6v
Also the dps is running a bit warm, (not hot)
The rest of the voltages are ok.
I also tried to reset the unit to no avail
I'm using this schem.
What can I do???
What can I do???
