Is it truly as transparent as true bypass? I hear degradation in pedals that even use buffers, so i've always seeked out TB or built my own with TB. But from my reading i'm hearing Millennium BP is good enough that you couldn't possibly hear a difference. What doth thou say?
Millennium bypass...as good as true BP?
I "invented" it, to the extent that it was invented. The original posting is still there (albeit updated) at my web site, Geofex.com. So I guess I have standing for the question.
The signal switching part of it **is** one variant of true bypass, so there is not and can never be a difference between the Millenium and "true bypass".
What the Millenium Bypass does is to use the output of the effect, which is disconnected from the signal path in bypass, as a means to light an LED for indication, while using only a DPDT switch, making a 3PDT switch unnecessary. At the time I came up with this, 3PDT switches were $15 and up. That price has changed...
The precursor to this was one variant of the Ratt, which used a bipolar for the LED switch. My minor contribution was to run the turn-on current down so low that there's no possibility of causing a switching pop.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Well, like usual that was over my head, but what i never ally thought of till now is that effects with DPDT true bypass cannot have a LED. So those TB effect of the old days had no LED i guess. I just don't recall that far back but i don't see how they can do it with DPDT. Thats where the 3PDT you mentioned comes in, but i never saw an effect that had that so i guess i never had a TB effect.
So while what you said was over my head, what i think i DID get from it is that you basically figured out a way to use a DPDT to get a bypass scenario that is NOT true bypass because it needs some of the switching potential for the LED, but is as transparent as TB because the amount of resistance is so high it can't make any audible difference due to loading. Is that about right?
Ok, I think i see now. In the image linked below it shows that it IS true bypass. It's just that theres a LED on when active and it is turned off when in bypass via a control with that is shorted to the board out. But it IS ture bypass in that the signal is 100% disconnected from the device wghen bypassed. the only difference between true bypass and this is this controls a LED w/o needing dedicated switch contacts. So when it's said this is NOT true bypass, thats a bit of a misnomer because it is actually TB, but with a LED circuit that TB till this couldn't have unless theres a 3P switch. Millenium Bypass 2 gif by roballey | Photobucket
The MBP makes use of the fact that the volume pot provides a useful path to ground for the LED subcircuit. The switch itself disconnects the input and output jacks from the effect circuit.
Much of the to-do about TB stems from the shortcomings of pedals in the 60's and 70's that only used SPDT switches and ended up loding down the signal because their input impedances were not high enough. Many contemporary pedals provide high-impedance input buffers, such that using a SPDT to select between the buffer and the effect out really is sufficient...as long as you don't need to switch a status LED.
Check this youtube video out. I think it is a good example of when true bypass works and when it doesn't.
I've been using the millennium bypass for quite a few years - ever since I read R.G's original article and I've found it to be totally transparent. But then again, I know a person who can 'hear' the tonal differences between the pickup selector positions on a Les Paul when it's unplugged and strummed acoustically......
Originally posted by Mick Bailey View PostI've been using the millennium bypass for quite a few years - ever since I read R.G's original article and I've found it to be totally transparent. But then again, I know a person who can 'hear' the tonal differences between the pickup selector positions on a Les Paul when it's unplugged and strummed acoustically......
Originally posted by cjlectronics View PostCheck this youtube video out. I think it is a good example of when true bypass works and when it doesn't.
