This seemed odd to me. I have a tube screamer clone that i recently got and it's as quiet if not more than my old tube screamers. It is millennium bypass. With a battery dead quiet when bypassed. Then i tried 3 adapters, one a boss pedal adapter and all of them buzzed, some loudly. I thought for sure the boss would be filtered quite well. Then i tried a old i dunno what that i had gutted years ago and mounted in a rack i made for use with a tube screamer. Thee screamer was never buzzy so i tried it and it was dead quiet. Then i remembered i has a 1 spot by visual sound, a boutique pedal co. Surely this one must be quiet. Nope...buzzed also !
Now i DO realize millennium bypass shouldn't be affected by any noise but it was. Maybe getting in thru the ground i guess. But why would this be? The pedal worked fine with all of them, but they all buzzed when bypassed except that one. I even tried turning the 1 spot around because it doesn't have one prong larger than the other so i was able to try that. But still buzzing. I will just use that one, but it's just the tranny and circuit board and no case and i don't want to make some sort of box for it. The others, especially the 1 spot and boss should be quiet, no? My only idea is a ground loop between the signal cable and the PSU's, but then why is that one quiet?
