I'm using an LPB-1 for a volume boost for leads in an effects loop. It works great except that it is usable only in a very sensitive area within the first 1/4 turn of the pot. If you accidentally bump the damn knob the gain can be overwhelming. Does anyone have a suggestion or know of a mod? I do know this is a common issue. Not sure if doubling the value would do much.
Changing the pot in a new Electroharmoix LPB-1?
Originally posted by J M Fahey View PostSchematic ?Last edited by olddawg; 01-29-2015, 12:16 AM.
If nothing else, replace the 100k pot with a 75k resistor over a 25k pot. voila, the pot only covers the first 1/4 of the original pot.Education is what you're left with after you have forgotten what you have learned.
Originally posted by olddawg View PostThanks for your response Juan. It's just a single transistor gain stage with a 100kA pot. I'm pretty sure the nano is the same. I don't want to change the transparency but make it more adjustable for the first half of the pot. I could change the total gain by changing the voltage divider network, but want to avoid that.
IF it's a true Log pot, setting it to around "4"(on a 0/10 scale) it's unity gain, meaning what comes in goes out unchanged.
So eithervthat pot is not Audio/Log or the preamp has some error and transistor is runni9ng full tilt.
Enzo's solution is right, but it *should* not be necessary.
To check pot curve, unplug the pedal, we need no power nor load nor signal through it, set it to "5"and measure resistance wiper to hot and to ground.
A Log pot should have roughly 90k mid to top and 10k mid to ground.
A Linear one will be roughly 50k/50k .
Please measure and post, before modding anything.
Just for the hell of it, re re confirm that it's actually wired as shown, as a typical voltage divider.
Maybe the schematic is fine (looks so) but the actual veroboard (or whatever you used) layout is not and wiper simply shorts output to ground.
Problem is, it will work, but in a crude way ... doing 90% of its job in the first couple points.Juan Manuel Fahey
