this is the part 2 of the thread talking about troubleshooting (for beginner!) the Echolette Tape echo NG51,The Gold Cage, with no echo sound .
Mickey, Oc, Mecaso i start an other thread here cause i can't reach our last posts..
With the Nachhall reverb on,reverb control fully clockwise, i tried to trace back the signal as Mickey suggested me.
-First i check the output din socket pin 3 and i can't hear no loud buzz trough the amp when taping the pin with a screwdriver.
I can hear a tiny buzz when i touch the pin 5&4.
I soldered the pin 3&2 on my din plug, so it seems that the dry signal is passing trough pin 3 but without producing a buzz when taping on it..
- then, still with the Nachhall reverb switched on, i move to valve 4 and with the tube slightly pull off i touched the pin 2&7 and there was no buzz
- I came to valve 3 and the same, no buzz at pin 2&7..
Oc, i looked at your diagrams and it seems for the valve 4 that i got the schem on top right of your pic,
but when i look at your picture of the valve 4 which i guess is the E 51, they look the same to me..
i tried to measure the playback head thanks to your diagram, and don't know if i succeed, but i've got oscillating readings sometimes toward infinite on playback 5
and a "1" on playback head 4 so an error reading.
Mecaso, lucky for me the tape is in the right position with the join faced out but this is a good thinking!
cheers guys
Nick
cheers guys
Nick
