After finally settling on the majority of a lineup of pedals that I plan on keeping long-term, I've run into some *noticeable* level issues in a "mostly on" and definitely so in an "all on" situation. (Granted, the latter's gonna be exceptionally rare, but... *possible* in some circumstance -with compressor/delay exceptions.) Currently: roughly double the output level when "all on" opposed to only 2-3-4 on.
Wondering what the best overall methodology ya'll have found or might suggest for getting an even level throughout the chain (assuming of course the keys lie in matching input impedances as well as levels -both input and output) whether you're using one pedal or a majority of them simultaneously.
As much as I love the convenience of the "all-in-one" effects racks, it's just NOT possible to get the same "love" from an effects rack, as what you do from the real thing (the pedal they're trying to simulate/emulate). Though I can definitely appreciate not having to deal with what I'm currently faced with, I've grown tired of getting "close" to "that sound".
These are all being switched via Digital Music Ground Control Pro and GCX's. Mentioned due to the GCX "loading" of each pedal (as opposed to the previous pedal "directly" loading the next). I'm half expecting it to be a uniform/expected load on each, thereby making things "easier", and just having to "calculate/calibrate each pedal" to it. Though if it IS "true-bypass" and it's just a relay in between...wouldn't the previous load be seen on the next pedal, and the GCX 'removed' from the equation? Ugh. Here I go again, thinking myself in circles. >.<
The chain is primarily:
one of the following compressors:
DOD 525-A compressor (just added today, may replace CO-04)
Vesta Fire CMP compressor (*phenomenal* for clean tones)
Pearl CO-04 compressor (best used with dirt/dist.)
then into one of the OD/Dist. boxes
Nady/Guyatone TO-2 Tube overdrive
Ibanez TS-9 Analogman Silver/Brown mod
MXR Distortion III
then into:
MXR Carbon Copy (long)
DOD 585-A Delay (short)
Ross Stereo Delay (medium) *definite problem child level-wise*
then:
Ross Phaser v2 (AM97C10CN) *definite level issues here too*
Boss BF-2 v1
In-Line Effects XE-600 Stereo Chorus (GREAT vibe sound)
Ibanez CS-505 Chorus (better than a TC Electronics S.C.F. IMO, sold my SCF as a result!)
I know that there's an issue by default when mixing vintage with 'new' primarily due to buffers becoming a common-place, but I'm also looking at just basic level differences between companies.
I believe most of my issues lie in the modulation areas, with the noteable exception of the Ross Stereo Delay which is famous for having level issues...but I notice the most bump in signal when several modulation units are active at the same time.
Your thoughts and input for a uniform method of attack would be appreciated! Especially if you've had to do this previously for your own/client's rig!
MXR Distortion III
then into:
then:
Boss BF-2 v1
