Been researching this pedal and sad4096 circuits. Havent found anything directly relating to this circuit. I have replaced all electrolytics in this pedal as they are some 30-40 yrs old I think. This issue was there before I recapped it. Initially the thing had no delay but a little twist of the bias trimmer brought it to life. The issue: high pitched squeal (clock noise?), and the delay turns into straight distorted noise as it repeats if i turn up the repeat pot. Basically the repeats sound like touching the tip of the input cable if the repeat pot is turned up to the point of compounding. Finally, the frequency of the squeal lowers as the delay time is adjusted. My main question; how do I adjust the clock to reduce noise, and what IS the clock? Is it the NE571?
Here is a link to the schematic.http://www.dirk-hendrik.com/temp/dod680.gif
