Line 6 DL-4 - No sound when effect is engaged (bypass works)
  • Line 6 DL-4 - No sound when effect is engaged (bypass works)
    I just traded a guy another pedal for this DL-4. Is in great shape and worked fine yesterday and today but then when I went to engage the effect again I got no sound. I did the factory reset and reseated (removed and reinstalled) the EPROM chip (sometimes that remedies some of the DL-4 issues) but neither worked.
    I've repaired non-powering DL-4s in the past but this doesn't seem to be a power section issues as the pedal powers up fine and all the functions seem to work properly.
    Any ideas on how to troubleshoot this?
    some links
    http://lazyecology.web.fc2.com/rever...line6_dl4.html
    Make sure the power supply voltages are proper.
    +5Vdc & +3.3Vdc.
    If that block diagram can be trusted, I would jump right to the ADAC.
    Look up the datasheet.
    Do you have signal in?
    Do you have signal out?
      Thanks. I had assumed the PS voltages were fine because the unit powers up but after reading the voltages in the PS section I found the voltages were not right coming out of a voltage doubler (U20). Was only getting near 2v. I removed it and ordered a new one. I hope that solves the issue.
