Mutron Biphase
  • Mutron Biphase
    Hello everyone, I´m cloning the Biphase and have arrived at powering it up and tweaking the LFO´s. Phaser B on it´s
    own with Generator 2 works perfectly: sinus and squared it does real slow(+-12 second cycle) to fast, with amplitude
    control by way of R127.
    The problem is Generator 1. Either with A and B or just A, the Rate-pot has one small turn spot halfway where it
    goes from superfast to hyper in a few degrees, resulting in a strobe on the effect-pcb. Generator 1 is pretty
    different from 2 and I haven´t come up with anything obvious doing a signal trace from start to finish. The actual
    LFO(either square or sinus) seems to be 213 A and B but the rate pot does virtually nothing there. Also, LFO trimpot
    adjustment R126 and amplitude trimpot adjustment R128 don´t do anything. 212A looks like a log amp, 212B a non-
    amplifying inverter and 215 A a buffer.
    I looked at the original schematics and they look the same except for R68 which on the original says 20k, but the 1
    may have faded.. Testing this made no difference though.
    This is the famous page where many a Mutron-fan resided for hours and hours: Patroche´s blog: MU-TRON Biphase MUSITRONIC - Plans et Clonage - Le blog de crazy-patroche.over-blog.com , where you
    can find all the schematics. Relevant here is the "Schema de Controle" and then the bottom part of it.
    Also here a simplified version with just the(in my humble amateur idea) relevant part(no pedal control), and the pcb
    as I printed and mounted it. Components were all checked and everything so far looks physically ok on the pcb.
    I´m studying up on building LFO´s but so far I haven´t been able to figure out where the problem lies here, and I
    would appreciate your opinions and knowledge,
    Many thanks in advance, Bram.
    Found it! Pin 2 on IC212a and pin 3 on IC213a were not grounded at C52/C50 due to having made a mistake on the redrawing of the board! It´s working fine now. Next setting up the LDR´s and audio!
    Any questions about my project I´ll gladly answer.
    Greetings, Bram.
