I've had enough shaky info from the actual owners that I still verify everything, especially if they have been in it.
So I'd still like confirmation that the 2 reds on the DC jack are going to the right places (tip and switch). Unless 52Bill is familiar enough with that type of jack to confirm from the photo.
I'm not sure from that which is tip and which is switch, and if those 2 are reversed, it will not work with the adapter.
I guess if you can measure 9V from ground to any point on the circuit board, that is confirmation enough.
