Does anyone know of a quick way to insert a resistor in series with the effect on/off LED? The LED is just too bright. Thanks.
CC Vibe LED brightness
Sure, do exactly that.
There already is a current limiting resistor in series with most any LED, so find it and change it to a higher value.Education is what you're left with after you have forgotten what you have learned.
Why can't you just unsolder one leg of the LED and put a resistor in series with the leg? You can leave the existing resistor and just add another. Or, is the LED SMD also?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
I have no idea what is inside a CC VIbe, but Dude's idea sounds fine to me too, if the LED is not SMD.
I would bet my lunch money the LED is not wired through the stomp switch. The switch controls the circuits that switch the function and the LED.Education is what you're left with after you have forgotten what you have learned.
