anyone know what the popular "mod" is going around for these od pedals? Is it just changing the chip and one of the output resistors? (kinda like the ts9 mod) ?
Boss Sd-1
Hi 496.
Well, i don't know if there's a "known" mod, but i bet the pedal could benefit from one! Big time, i think it sucks compared to a TS9. I haven't tried to retrace teh circuit, but they use the same chip as the TS9, so might be a cheap copy of it! Or i'm could also be talking complete gibberishImho, try to put a switch bypassing the tone control for mo gain for example. And may be dig a bit on Geo!
Bye.
Max.
There's really nothing special about the chip in the TS 9. It's just a 4558 dual op amp.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://www.geocities.com/overdrivespider/SD1/sd1.htm
Just remember it's all salting to someone else's taste. But for the small costs involved, what have yo got to lose? Try it, and deduce how to take the ideas further, if you like salt that much.
"You can lead a horticulture, but you can't make her think! "
Here's a mod for the SD-1 that I call the Fool Clone:
D6 - Germanium
D5 - 1N4003
D4 - 1N4148
C1 - .1 uF Metal Film
C2 - .022 uF
C3 - .1 uF Metal Film
C6 - .022 uF
C10 - 1 uF Metal Film
R6 - 2.2K
I know that I'll see this all over the place after a little while, from the name you can figure out what "famous" pedal that it sounds like.
I just discovered that my mod is very similar to the Indy Guitarist mod. This is pure coincidence. The diode clipping section is different, but most of the replaced parts have the same value. I do change another cap in my mod also.
Maybe it's that "great minds..." thing?
