Folks,
I have a DD-3 that passes the signal through ok, but no delay effect what-so-ever. I've checked the PS (battery) and on most components that I can get to or can figure out pin-outs, I get 8.x volts or 5.0 volts where I need it.
However, there is a chip on the board and the schematic that is a bit weird. As far as markings & documentation. The chip marked IC4, a 4066, on the schematic, is showing pin 8 as ground and pin 8 as 5 volts. BUT!!! When you look at the actual chip, there's only 14 pins!!
Add to that, I cannot find a data sheet for it anywhere. The part number 4066 for NTE is some sort of Darlington power IC. If I type in 4066BP, all I get is the number NTE4066B, but no data sheet. So, even though it's a different NTE number I don't know if it's the replacement configuration I need.
Anyhow, I think that device is part of the problem since I either get nothing on some pins or 4.x volts on other pins.
The chip itself has "HD 1 4066BP" on it.
So if anyone has any info on this device, I would appreciate a bump in that direction.
Much appreciated in advance!
Andy S.
Andy S.
