I don't do this much anymore. In the old days I just parallel up the inputs and delt with ground loops with ground lifts and ignored any loading problems. I'm playing a high profile situation where I will be using multiple amps outdoors. I'm not switching between amps. The last pedal in my chain is a buffered pedal (Ibanez DE 7). Will that be enough to avoid the usual issues if I just use a simple Y splitter after the buffered pedal into 2 amplifiers? Or do I need to use a dual buffered splitter like the JHS Buffered Splitter?
Using one buffered pedal to drive multiple amps....
It would be best to have a buffer feeding a direct output and one via an isolation transformers, see http://www.geofex.com/FX_images/splitter.gif
This will avoid a connection between the signal 0Vs of the 2 amps, which is what creates a ground loop (assuming that the amps are properly safety linked via mains ground).My band:- http://www.youtube.com/user/RedwingBand
Originally posted by olddawg View PostI don't do this much anymore. In the old days I just parallel up the inputs and delt with ground loops with ground lifts and ignored any loading problems. I'm playing a high profile situation where I will be using multiple amps outdoors. I'm not switching between amps. The last pedal in my chain is a buffered pedal (Ibanez DE 7). Will that be enough to avoid the usual issues if I just use a simple Y splitter after the buffered pedal into 2 amplifiers? Or do I need to use a dual buffered splitter like the JHS Buffered Splitter?This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostYour last pedal being buffered, you'll have no problem losing bandwidth splitting into two amps. BUT you still have the ground loopage to contend with. pdf64 suggests the geofex diy, and that's good but a bit more complex than necessary. There's a commercial item, Radial Bigshot for $90, has no internal buffering just a single transformer & a couple switches. If you buy one, put some extra glue on the transformer as it likes to tear loose from its circus board. Or build yourself a Bigshot copy, choosing which switches you may or may not need. It's very handy to have a polarity flip switch if you use two amps simultaneously. The Mouser TL018 transformer suggested in the geofex schematic works fine; I've used it to replace Bigshot transformers that broke loose & left no wire to solder to.
Originally posted by olddawg View PostMost of these passive switcher/splitters have one direct out and one isolated out. Is there any signal loss with the isolation transformer and does it have to be treble compensated on that output? I'm very surprised that I can find a simple inexpensive passive splitter with isolation. Everything is an A/B/Y switch.
There's no reason not to use 2 transformers if you're concerned that the direct & transformed signals will be different in level & eq. Still cheap.
One hazard with iso transformers: they will pick up hum from stray magnetic fields so place your split box somewhere it won't pick up hum. Away from wall warts & power transformers of all sorts. One of my crustomers bought a stereo line isolation box, then parked it right atop the power transformer in his Mesa 90+90W amp. Woooooops! Moving it to the other side of the rack, quiet as could be.This isn't the future I signed up for.
Forgive me if I'm stepping on any safety toes, and I'm not out to uncomplicate a problem that needs solving if complicated is the goal, but...
If all the amps have the circuit ground at the chassis and there is a ground loop then there is also redundant chassis grounds. Why not just make an AC plug box with ground lift switches.
Please ignore if any of the amps aren't using the chassis for circuit ground.
EDIT: I know that there are arguments for not doing this because "What if a cable is kicked loose?" or "What if the grounded amp gets unplugged?" I'm the only guy in control of my gear when I'm on stage and I damn well know if either of those things happens. These aren't more than potential and momentary rare possibilities that need to be solved for before continuing anyhow. More convincing is that with AC ground lifting the chassis grounds for the AC ground lifted amps is actually using the instrument cable shields. I'm honestly not too worried about this either, but I can understand if someone else is.Last edited by Chuck H; 03-06-2016, 12:37 PM."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostIf all the amps have the circuit ground at the chassis and there is a ground loop then there is also redundant chassis grounds. Why not just make an AC plug box with ground lift switches.
That will allow various jack sleeves, amp chassis, fx pedal metalwork, possibility even the instrument (and so that player) to be pulled up the mains voltage, thereby presenting a fatal hazard.
Not just only to the player, but to anyone that they come into contact with whilst energised.
Safety systems have been developed, implemented and maintained to mitigate risk; there's a cost associated with that but it's a safe bet to assume that cost is lower than the cost to human life, however that might be extrapolated.
So it may be seen to be a reckless risk to human life to disable / bypass such safety systems, with criminal and civil liabilities probably falling on someone taking such action.My band:- http://www.youtube.com/user/RedwingBand
Originally posted by Chuck H View PostForgive me if I'm stepping on any safety toes,
FWIW I made a 5-way iso splitter for a customer in 1998, much along the lines of what Dave H shows in post #8, with mute switches and transformers following each output op amp. Nothing too special, I snitched the circuit from Bob Bradshaw, just used affordable Mouser transformers rather than rock star priced Dean Jensens. Worked a charm!This isn't the future I signed up for.
Well sure, there's THAT
I agree that maintaining a fixed ground for each system is the only guaranteed safe thing to do. But I also know that the lifting AC grounds when connecting multiple amps was common on big stages at a time when the players amplifiers were their only source of volume. And I just haven't heard of anyone being shocked or electrocuted by doing this. Other reasons, but not specifically this. I've been shocked because of inverse wired AC plugs though. Which is also a good enough reason to isolate the instrument.
I only mentioned it as a possibility because if I were up against a time limit and didn't have time to order something I would probably handle it this way. I know that's not the case here, so safety first."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostI agree that maintaining a fixed ground for each system is the only guaranteed safe thing to do. But I also know that the lifting AC grounds when connecting multiple amps was common on big stages at a time when the players amplifiers were their only source of volume.
Originally posted by Chuck H View PostBut I also know that the lifting AC grounds when connecting multiple amps was common on big stages at a time when the players amplifiers were their only source of volume. And I just haven't heard of anyone being shocked or electrocuted by doing this.This isn't the future I signed up for.
