Digitech Whammy 4 problem
  • Digitech Whammy 4 problem
    Been using this pedal a few years now. But not very much. Started having a problem. plug it in, all lights come on and stay on. Had a local music shop, open it up. And this is what he found.
    looks like something dripped down onto frame. any idea's. thanks
    Looks like a capacitor exploded at the top and it spilled onto the metal plate.
    Can you remove the pc board from the mounting posts and inspect the cap?
      Sure looks like capacitor guts.
        I'm trying to repair a Whammy 4 right now. Also problems with the power supply. A real ugly stench coming from what I gather is a regulator.
          ok, I'll look into that today! thanks
            yep! the capacitor thingy in the middle is swollen on top, and looks as though it leaked on the housing. what the heck would have caused that! I very sparingly used this pedal over the years. So what do
            I have to do? send the board somewhere to get it replaced? I live nowhere near an electronics store. I'm like, hours in the mountains. thanks again
              Then box it up and mail it to someone who knows what they are doing.
              The bad cap needs to be unsoldered from the board and removed, and the cap guts needs to be thoroughly cleaned away. Then a new part is soldered in place. We also need to determine if there are more problems inside. That cap might have simply failed, or it might be a diode shorted and left AC on the cap. Or, and the very first suspect in my book, someone plugged the wrong power adaptor into the unit.
                That someone had to be me. I've got a lot of pedals and adapters. wow, that is not good. ok, thanks
