Boss GT8 error
  • Boss GT8 error
    I'm electronic technician, I have a multi-effect GT8, when turned on shows a row of lights on the display. Anyone know what can it be? or I can check? The voltages of the internal power supply are good. Thank you
    Hi, welcome to the forum. Our member Juan Fahey is Argentinian as well.
    Start with this:
    http://bmamps.com/Schematics/Boss/Bo...ice_Manual.pdf
      I would check the battery and do a factory reset, first. Question: Is it just the display that's goofy? In other words, does the rest of the unit function- make sound, change patches, etc.?
        The battery is ok, 3 volts. I can not reset or change sounds or patches. If I turn off and turn on several times, all the LEDs light up and the bank shows "88".
          I will read the service notes tonight.. Thanks a lot.
