Looking for the pot pcb (or pics/layout) from a Rotovibe
Not in the flesh but found this:
Apparently just the pot and a switch so if you get the circuit schematic somewhere, in principle you can add missing parts (still unmounted) and test it for functionality.
IF it works (hope so ), making the simple PCB or even using a piece of perfboard will restore it in full.Juan Manuel Fahey
I have that exact picture as well....unfortunately it doesn't show the pot connections...nor the switch connections...
Or even no board. A zillion wah pedals are out there with the stomp switch and pot just wired to a connector for the main board, or even wired direct.
Did you CALL Dunlop and ask for a schematic or other notes? Have your serial number handy, sometimes it tells version.Education is what you're left with after you have forgotten what you have learned.
Originally posted by 52 Bill View PostI have one of those pedals somewhere. If you are not in a hurry, I'll look to see if it is the same model that you have. If it is, I'll post a few photos if you still need them.
