Hi!
I hope you can help me fix a dead Line6 DL4 that won't power up and it's giving me headaches.
First, the schematic:
https://www.docdroid.net/JYZyjup/tmp...48780.pdf.html
I disassembled it and made a visual inspection first. Nothing wrong. I did check voltages, all correct till U14. Touched U14 (MAX887) and was very Hot and giving wrong voltages. Pin 7 was giving 0V instead of 3.3v.
A bunch of components are fed by the 3.3v line, with U2 (DSP56364) being one of them.
After a lot of tracking, I found out that if I cut the 3.3v trace near pin31 of DSP56364, the voltage of the whole line is restored and MAX887 operates correctly.
I thought that the DSP56364 was shorted, so I replaced it with a new one (super expensive, BTW) and didn't made an improvement. MAX887 is still very Hot and 3.3v drops to zero as soon as the pin31 of the DSP56364 is connected.
Here's the DSP56364 Datasheet :
http://www.nxp.com/files/dsp/doc/dat...t/DSP56364.pdf
Any ideas on this? What could cause the short?
Many thanks guys
Many thanks guys
