Line 6 MM4
  • Line 6 MM4
    Had a Line 6 MM4 come in.
    Would not power on.
    Checked all of the voltages, which where good.
    3.3Vdc came up when a cord was inserted into the input jack.
    Pressing any key did nothing.
    Tried a master reset at power On (Hold A and D keys down, power On)
    Nothing doing.
    Scoped the crystal. Oscillating fine.
    OK. Now what.
    I used a 10X magiifier a looked at the main microcontroller.
    Some of the solder pads looked iffy at best.
    So I hit it with my Weller 750 degree heat gun and then popped it in the freezer for 10 minutes.
    Lo and behold!
    It works.
    Thought I would pass this on.)
    Here is a voltage measurement schematic.
    And a brief of how the power supply functions from a gentleman in Scandinavia.
    Is the freezer part some trick or just so you can handle it?
      More than anything, I wanted to make sure the core of the ic was cooled down.
        Well, after 3 hours running , it locked up.
        Pulled the Eprom out & gave the pins a quick wipe with DeOxit.
        Now it's working again.
        Stay tuned.
