I've seen the schematic kicking around for this noise gate for quite a few years and decided to see how it functions. Not very impressed initially, but with a few tweaks it's showing some promise. It needed a 4.7uf cap form Q3 gate to ground to give it a smooth release, otherwise it's very abrupt and kills the note decay. The cap coincides with my Tele's natural note decay and it's just right. It works much better with BC109C for Q1 and Q2. The threshold control doesn't do much - turned right down it introduces distortion, but slightly turned up and the circuit operates without distortion even on high signal levels. It needs a series-resistor to set the minimum undistorted threshold. Also, 1M is way too large and 100k is better.
It's super-quiet and transparent but there are problems;
1. To open the gate it needs a high signal level, but following this the guitar can be played normally - even the volume control can be rolled off and it will still play until you finish the last note and then it closes nicely. Then it needs the high initial signal again to operate.
2. The attack is very abrupt; so fast that it's clicky. It needs just a little easing-off to soften the initial response.
Overall this could be a nice circuit that could be built as an add-on to an existing pedal, or stand-alone. I have it breadboarded right now as a side-project
