I have a 1983 OC-2 It runs on ACA-120 I tried using a Y on a PSA but the light is dim,and on my1984 Boss SDS DDL the manual says NOY to y..Can someone explain in DAB terms what can I do to use a PSa120,if you say short it out what or how do you do it...It is a cool pedal after you master it some..I don't want mess it up
Boss OC-2 Octiver Adaptor ACA120?
see what g1 wrote in #5Last edited by Leo_Gnardo; 10-30-2018, 03:11 AM.This isn't the future I signed up for.
The ACA is DC but unregulated. The PSA is regulated. The ACA puts out higher voltage at lighter loads. This mucks up the LED when you use a ACA pedal with a PSA supply.
The problem is outlined here:
http://stinkfoot.se/archives/726
Solution is to either mod the pedal like this: http://stinkfoot.se/archives/1019
Or you can just use it along with a pedal designed for the PSA (Boss SDS DDL?) as outlined here: https://reverb.com/ca/item/527381-boss-aca-120gLast edited by g1; 10-30-2018, 06:27 PM.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
^^^ that right there.Last edited by Leo_Gnardo; 10-30-2018, 03:12 AM.This isn't the future I signed up for.
