The potentiometer for the expression pedal on my ME-25 wore out, so I opened it up and found it was an ALPs RK11K series, 10K ohms.
My brother has the older ME-20, which still works OK, so I opened it up and checked the potentiometer in that one, also an ALPs RK11K (10K) and using an ohmmeter, it looked like a linear taper. I found the datasheet for the RK11K series and determined that the RK11K1150A3L part was the best match as far as I could tell. So I ordered a couple of new potentiometers. I installed one of them in my ME-25, now the volume function does not work, full volume all the time, Wah-wah still works but not like it used to. Has anyone successfully replaced one of these and if so, what part did you use?
