I have a black label CE -2, serial number 0000 on the bench. Pedal works well but has a ticking on or off and also notice a volume loss when comparing the pedal in and out of the chain. I've replaced all the power supply caps. The only thing left are the 1uf caps. I've checked the caps that I have pulled and they all test okay. ESR checks good on the remaining 1uf's. Surely they didn't let this thing leave the factory with these issues so I'm struggling to figure out what to fix. Weak chips? I may try to add shielded cable to the rate pot or Mark's mod with the resistor on pin 6 of the LFO. Any other thoughts or suggestions?
1980 Boss CE-2 ticking
