I'm testing out a simple clean boost circuit that's just an op-amp in a non-inverting amplifier configuration (see schematic). I'm getting an issue with pot scratching at the highest gain portion of the knob, and I can't figure out how to get rid of it.
From other forum posts (i.e. https://music-electronics-forum.com/...hlight=scratch), it looks like DC across the pot is a typical source of this kind of issue.
When I check the DC level on each end of the pot, I get 4.01V on the C4 side and 4.61V on the other, when the pot is at its min position, and 4.58V and 4.61V when it's at its max position. So there definitely is some DC current flowing through that pot. Interestingly enough, the DC differential actually gets smaller in the region of the pot where I'm getting the scratching (towards it's max position), but I guess with the gain being so high there it probably takes even less DC to pose a problem (assuming that is the source of this issue).
I'd be interested in your opinions on whether you think the DC on the pot is indeed the issue, and if so, how to fix it?
I've tried subbing in a 1u film for C4, thinking it was related to the ESR, but it didn't seem to make any difference.
I have a PCB made up for this circuit and one thing I've noticed is that the scratching is less severe when everything's soldered to the PCB. Especially I noticed that when I took C4 off and put it on a breadboard via a couple test leads (to experiment with changing the component), the scratching was much worse (almost unbearable). So maybe something could be improved with the layout? But not sure what – it's a simple circuit so everything fits pretty nicely. I've got 24mil signal traces and a bottom layer GND plane that's relatively uninterrupted (can post screenshots if people want).
As a final sidenote - I don't think it's related to the problem but I'd just really like to understand it anyway – I realized that the DC levels at the op-amp inputs aren't equal... at the non-inverting input I'm getting about 2.35V, and at the inverting I'm getting 4.61V. I'm wondering if that means I'm operating the op amp in some kind of region that it doesn't like very much?
Any help would be much appreciated!
