Hi,
I've acquired a free-but-dead ~1990 ProCo Vintage Rat, the re-issue of the large format original. The prior owner said it worked last time he used it a decade ago, but it turned out to be dead when I tried it out. Here's what I've figured out so far:
- it passes signal just fine when on bypass (switch off) whether there's a battery present or not
- it doesn't pass signal at all when switch is on, again whether there's a battery or not
- if you short out the battery connector (no battery, just a conductor across + to - terminal) then it does pass signal (albeit poorly) and the volume pot does attenuate the sound (obviously it doesn't distort).
That suggests that there is a complete circuit, right?
I can't see anything obviously blown or leaking.
Where should I start looking? Bit worried that the op amp chip might be fried, is that something I can test?
I have fair soldering skills and a multimeter and a desire to see this work, hoping someone can give me some pointers.
Thanks.
Thanks.
