I got a Klemt Echolette a couple months ago and found some Dynacord pinch rollers being sold on Ebay and was wondering if this would work on an Echolette. The dimensions of the pinch roller on my Echolette are
20mm OD x 7mm ID x 12mm long
Some more details:
I used a dental mirror to look at the bridge rectifier and since its selenium (B 300 C 70) I decided to put in a silicon type bridge rectifier (KBPC50-10) to substitute for it. I checked the motor capacitor and two filter capacitors with an analog ohm meter and capacitor tester. The motor works (both speeds, bridge rectifier disconnected during the test). After that I connected the silicon bridge rectifier in place of the selenium (left in place but disconnected) with a 250 ohm power resistor in series with the new bridge rectifier. With a variac and ammeter connected, I slowly brought up the voltage and figured it looked OK. I tested the tubes with a tube tester and they look OK. I put the tubes in and turned it on with a microphone connected via a home made adapter with a 3 pin DIN connector and phone jack and connected the output to an amplifier. It worked with the mic connected, but there was no reverb. I connected a jumper between two pins of a 3 pin DIN connector plugged into the remote control and the reverb worked with some problems with the tape I can discuss later. It seems that it was a bad connection at one of the pots which I fixed. More recently I replaced the roller on the spring biased arm with a new polyurethane roller. It works good in the slow speed when I put my finger on the pinch roller arm and push it toward the capstan. If I had a new pinch roller it might work better.
Also, I used a 9 pin tube adapter/tester (ie. Pomona) between the tube and socket and checked the grid and plate voltages on some of the tubes which seem OK. There doesn't seem to be any bad interstage capacitors (no shorts).
Some more details:
