Marshall ED-1 compressor
  • Marshall ED-1 compressor
    I need schematic of Marshall ED-1 compressor pedal. Is it similar to Mxr Dynacomp?
    It is somewhat similar to the Dynacomp, but the extra control allows the user to select whether it is equally responsive to the entire audio spectrum, or more sensitive to bass content ior treble content. It's kindof like the Big Muff Pi tone control, but placed between the gain cell and the envelope-follower/rectifier. Someone posted the schematic but I don't have the link or file on me at the moment.
      There is no schematic for it on my dealer site, it is a "replace only" unit.
        Why do you need the schem? For a repair? clone? intellectual stimulation?
        Not challenging you, just trying to figure out what the best recommendation is. I have the schem at home but it is practically drawn so as to prevent comprehension. If there is something more useful I can provide, it would help to know the goal you have in mind.
          Thnx people, especialy Mark, well I need the schematic for building clone, but also cause Ross/Dyna comp is my favorite comp, and just wanna to compare it with Ross (and by that I mean is it use same CA3080 ?!).
          Thanks Mark your posts are always very clear and helpfull.
            You're welcome. Glad to be of service.
            I'll tell you right now, the schematic is a very poorly drawn one. Not that the physical document is grainy or fuzzy. It is a very clear factory-issued PDF from what I understand. It is just ridiculously difficult to follow because of how it is drawn.
            In many respects, you could duplicate what the ED-1 does simply by cutting some of the bass or treble being fed to the sidechain, so that it responds more to high-end, more to low-end, or responds equivalently to everything. Apart from that, I can assure you it doesn't really do anything that a Ross/MXR doesn't do.
            I'll see if I can locate it over the next few days.
              OK, I have the schems. Where can I mail them to?
                acahool@yahoo.co.uk
                thanks Mark
                  I have an Ed-1 that somebody poured what looks like beer into it. It doesn't work - big surprise.
                  I'd also like the schem for this if I could.
                  jeff at jeffgross dot com will get it to me
                  Cheers
                  My Momma always said, Stultus est sicut stultus facit
                    hi, I own an ED1 too and with my fender stratocaster and deville amp it crunches, does anybody knows why, or colud send me the schematic so I could try to solve the problem by myself?
                    thanks
                      Here you go, gents.
                      http://img.photobucket.com/albums/v474/mhammer/ed.gif
                        Did you redrawn that yourself?
                        The factory has it online now, I posted a pdf of the original on www.ampix.org in the Enzo gallery, just for reference. it really is a chopped up pain in the ass.
                        For lack of a better term, I call those engineering drawings instead of schematics.
                          Hey, thanks for sharing that! I have one of these pedals too, and I've always wondered what in heck the "Emphasis" knob did (but not nearly enough to dismantle it and trace the circuit...) So it's basically a Big Muff-style tone control in the sidechain?
                            As near as I can gather, that is what it does. That is it changes how sensitive the sidechain is to different parts of the frequency spectrum. In principle, you could tweak it to be a de-esser by positioning the treble end of the emphasis control to emphasize the sibilant frequencies.
                            Enzo,
                            Someone else at the diystompbox forum redrew it. All I did was save it and post it. And yes, the Marshall schems are an absolute bugger to interpret. Almost as bad as the Boscorelli drawings!
                              Those drawings should still be helpful to someone trying to TBP mod this pedal, by teasing out what the heck is going on on the jack-pcb. IMHO, tone-sucking is its only shortfall. I assume those beads are to get rid of RF? In a TBP iteration, would they be necessary, or could they all be inside the bypass, along with the effect?
