Tie-Down Resistors??
  • Tie-Down Resistors??
    I have a few passive stomp boxes I made which are items like an EFX order switcher, a/b/y box and a true bypass box. The only thing requiring power is the LED in which I use a 9 Volt battery.
    My question is that when I stomp the switch I get a popping noise sometimes. I was told that you use "tie-down" resistors to correct this. What value do I use and where exactly does it go? Does this correct the problem?
    Also, I was thinking of adding a power jack so that I can plug in a boss power supply or other. Would this affect anything?
    Thank you.
    The popping sound your getting is probably the LED turning on. Go to Rg Keens site he has a fix for this problem. Its pretty simple, its just an added cap to ground and a resistor between the LED. It works pretty well. Hope this is some help.
      Ok. I wasn't able to find his site. Do you have a link? Thanks.
        Geofex
        http://www.geofex.com/
        Definitely bookmark this one... a LOT of good info.
        As is outlined in the article in question (search "switch pop" on GEO), you can solder something like a 1Meg resistor from the input to ground. That's the easiest thing to try. R.G.'s site outlines a couple more methods...
