YES! I have another broken pedal and could use some help.
After replacing the switch the unit does power on and clean signal passes through. When engaged the effect does not go through. This unit has an LED that flashes according to the the SPEED. This LED does flash accordingly.
My guess is the ICs? One is bad. Am I right to think this?
Thank you.
1981
Thank you.
1981
