Where to find enclosures???
  • Where to find enclosures???
    Hello,
    I am surching for big pedal sloped enclosures in order to build a midi footswitch.
    Here is what i need :
    I am also surching for a box like the ENGL E430:
    Thank you for your help !!!
    Alex
    Hammond makes lots of sloped front chassis. While fairly sturdy, do keep in mind they are intended for benchtop use not floor use. Consequently, you may want to incorporate some sort of internal bracing or support just to make sure the unit doesn't cave in from stepping on it too heavily.
      If you can find anyone local that does sheet metal fabrication, it might be worth giving them a call.
      I tend to build most things into flight case "basemaker", just because you can then make a lid for them and sling them in the van without worrying about damage.
