I have an OD called a Blue Balls from Blues Pearl (now defunct AFAIK). After tracing the circuit and comparing it to some schematics of common pedals, it looks like the input buffer, output buffer, and tone control (using a single op-amp) are almost exactly like a Tubescreamer. Other than that it's a dual op-amp with both sides cascaded, then clipping diodes to ground (actually to Vref), then the tone control (third op-amp), then output buffer.
The only difference I can see from the TS tone control is that the 'fixed' LPF in the BB is 1K (series) and .1uF to ground instead of 1K/.22uF as in a TS. The tone control still uses the typical 25K pot/.22uF cap/220 resistor.
The problem is that the tone is too dark until about 3:00 and then too bright shortly after that, i.e. the useable range for the tone control is very small which makes it difficult to dial in. So what are some mods to try to increase the useable range of the tone control? If possible, I'd rather just solder something to the pot since it's so much easier to get to...but if I have to I'll lift the board up again. Any help appreciated.
I think the fact that this tone control is sort of 'half shunt/half feedback' contributes to the fact that I don't fully get it.
PS - I tried adding another .22uF cap, I soldered it to the tone pot wiper and moved the connection (that goes to the board) to the other side of the cap. Didn't really cure the problem and (unless my ears played tricks on me...entirely possible) I thought the pedal didn't sound quite as good.
