hello, i'm building a basic boost circuit as a first project to build some experience reading a schematic. numerous times the plan calls for a ground, with that dashed-arrow symbol. how do i handle this?
here is the schematic:
2- another question I have is how to handle the top bit. is that the positive side of the 9v battery connector going off into the circuit while the negative side goes down to the input?
3- also, how do i connect the wires to the input/output? there are 3 little connection spots on the 1/4" inputs that I have, and the schematic doesn't saw which side is connected to what. does it matter?
