Anyone build this pedal? I just finished my first one. I built the jfet matcher and matched 2 jfets for the differential section. I am also incorporating the millenium bypass too... It is doing something, sounds like even order harmonics, however the effect is much thinner sounding than the straight buffer signal and a kind of ugly distortion too... i.e. when I turn the mix pot to ALL effect it sounds thin and when turned all down to just straight buffered signal it is a fatter sound w/ more lows. I know it's not wired backwards because the effect is only really happening when it's up all the way and thin sounding. The thing has a fairly unfavorable distortion going on too.
What might cause this?
Is something wrong or is this what others who have built this sound like too?
If it sounds like something's wrong what might I check? What should the transistor voltages look like? I am getting what RG says in the article on the sources of the differential - 1.5v.
I have gone over it a lot and the connections seem correct, maybe I fried a component or jfet when I first fired it up?
