Source parts for R.G. Keenes Spyder power supply
    Not ground loops, no.
    SOme pedals ground the +9v while others ground the -9v. If you ground something, then you can't ground the other end. In other words if you ground the - side of a 9v, then you cannot use it where + ground is needed.
    Think of this supply as a battery substitute. each section creates an independent 9vDC - just like a battery. Now floating like that, a pedal circuit can ground whichever side it wants - or neither side in some cases.
      Thanks!
