I have just picked up an old Deluxe Electric Mistress from ebay but the unit hummmmms alot and unpon further investigation I discovered at some point that somebody has replaced the transformer inside the unit (it also looks unsheilded). Is anyone here able to give me the specifications of the transformer that was used and maybe also recommended a replacement ?
Many Thanks
Mark
EDIT: By the way I am in the UK so need a 240v supply. I am also tempted to use a Toroidal Mains Transformers - due to the "Very low magnetic leakage field - ideal for audio, video and measuring techniques". I have found on here but not sure about the rating, anyone know:
http://www.maplin.co.uk/module.aspx?...36677&doy=15m8
EDIT2: I have also discovered that (I THINK!) it uses an 18v transformer so I managed to find an 18v Toroidal from farnell as per:
http://uk.farnell.com/jsp/search/bro...equestid=35829
Problem I have is that there are 3 to choose from and i am not sure what the rating is for the EM:
3.2VA:
http://uk.farnell.com/9531467/electr...comp-mcfm32-18
5VA:
http://uk.farnell.com/9531548/electr...comp-mcfm50-18
7VA:
http://uk.farnell.com/9531610/electr...comp-mcfm70-18
I have also discovered that RS do these also:
1.6VA:
http://uk.rs-online.com/web/search/s...duct&R=2786807
3.2VA:
http://uk.rs-online.com/web/search/s...duct&R=2786891
7VA:
http://uk.rs-online.com/web/search/s...duct&R=2787002
Many Thanks
Mark
3.2VA:
5VA:
7VA:
1.6VA:
3.2VA:
7VA:
