Reading Phase 90 LFO on Scope
  • Reading Phase 90 LFO on Scope
    Hi all,
    I'm not a scope expert by any means, but I always have trouble with scoping certain low frequencies.
    I have a Phase 90 I'm troubleshooting (along with a working version for reference), and cant seem to get a good read on the LFO output.
    I have my scope set to AC Coupling, 2v division, and 500ms division.
    What I do get is an occasional wave read if I lift the probe and place it back on the terminal, but just a flat line after. I have the probe ground on the pedal's ground.
    Any advice?
    Thank you.
    Try DC coupling. The frequency might be too low for the AC coupling cap in the scope input. Could also be a trigger problem.
      Thank you Helmholtz , I will try both your suggestions.
      As for the trigger, I have on auto. Will try some manual settings.
