no pop when shorting 2 to 3!
MOD Verb Deluxe Reverb kit mechanical switch click
Originally posted by The Dude View PostPlease solder the cap in. You can't expect proper results with it just laying on the contact points. I'm not sure why you wouldn't anyway?
You have to remove the wire going from pin5 to ground. That is what nick meant about the cap being shorted out by a wire. The fix won't work if you leave that wire there.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
