hi guys, got the urge to make a tubescreamer-like pedal the other day. after debugging the build i now get sound, but it is only the clipped signal coming through. as you strum hard, it gives a clipped signal, which dies away quite quickly. essentially i am getting the clipped signal through the clipping diodes, as well as some high freqeuncy content that comes through the 51pf cap. the drive pot will adjust the amount of signal coming through, as well as limit how long it stays (as the distorted content will reduce as the attack declines).
here is the schematic i am working off
http://www.schematicheaven.com/effec...truebypass.pdf
on mine i am using an LM358 as it was suggested on another schematic. i've checked the pinout, which is the same as on the schematic.
i have used led's for the clipping diodes
i am using 2n3904 for the transistors
changed the input cap (C1) to 0.047uf
changed C3 to 0.1 uf
i am using a board with strips of connections attched, and use wires to connect perpendicularly to the strips. i used a drill to break the strips where it was neccesary for the circuit.
what could the problem be? ive checked that there is not a cold solder joint at pin 1. all controls seem to be working correctly (other than the level pot soldered backwards). the tone control hasnt been able to do much, but i'd say thats bacause the clipped signal still sounds clipped when on.
the way i see it, the problem is between the pin 1 and 2, or within the first op amp. does the op amp amplify the clean signal out from pin 1? or does it flow through the drive pot?
sorry if the questions are a bit silly, i am more of a tube guy, and have very limited knowledge with transistors.
