Vox Tone Bender - how old is it??
  • Vox Tone Bender - how old is it??
    I bought my Tone Bender in Nashville in the 1990s.
    My theory is that it is a V828 (rather than a Mk1.5 or similar) made in 1967
    There's nothing in the wiring to suggest that this is anything but all original.
    The only issue I'm aware of is the heatshrink I put on when the battery wires
    got slightly damaged.
    It has SFT337 and SFT363e transistors in it - I think this means 1967 is likely ...
    There is no cap under the board which I believe makes 1967 likely ...
    The placement of the logo below the knobs makes it 66-67 I THINK ...
    Can anyone help me be more certain / precise about the date?
    I couldn't find a Vox-specific forum easily ... can anyone suggest one?
    Many thanks,
    Danny
    Click image for larger version  Name:	122573256_10158940164736291_4125298906407801089_o.jpg?_nc_cat=105&ccb=2&_nc_sid=e007fa&_nc_ohc=LNESjcOBxEcAX8KmRbR&_nc_ht=scontent-lht6-1.xx&tp=7&oh=293a56dec0e9716929b6cbe1a85f1202&oe=5FBA2233.jpg Views:	0 Size:	69.5 KB ID:	916389
    Click image for larger version  Name:	122493543_10158940164761291_7815564681996918014_o.jpg?_nc_cat=100&ccb=2&_nc_sid=e007fa&_nc_ohc=0s0zX8abBiAAX9njJi_&_nc_ht=scontent-lht6-1.xx&tp=7&oh=07b6044d2457767f3a9e063e546b55a5&oe=5FB694E4.jpg Views:	0 Size:	67.8 KB ID:	916390
    Click image for larger version  Name:	122529826_10158940164796291_1019513153158710752_o.jpg?_nc_cat=109&ccb=2&_nc_sid=e007fa&_nc_ohc=R7p9eHvR4FcAX9tUOIu&_nc_ht=scontent-lhr8-1.xx&tp=7&oh=a7187af6e6f87d52fec4da4b07211519&oe=5FB84DC5.jpg Views:	0 Size:	129.1 KB ID:	916391
    Have you tried diystompboxes.com.
      cheers
        Look here: http://www.voxshowroom.com/us/misc/v828.html
          Thanks, I saw that but my pedal doesn't resemble either in the picture. Yet other sources imply that it IS a V828 ... is strange
            Looks close enough to me. It's obviously a V828. Yours might even be a bit older than the one pictured at the Vox page, as it has an older type switch and a tropical fish cap.
            I just did a similar research for a '68 Vox Wah. Those Jen manufactured effects had many component variations even within the same year.
              Do anything write (except value) on pots or elco?
              It's All Over Now
                This page implies it is a Mk1.5
                https://www.premierguitar.com/articl...ne-bender-fuzz
                And this one says V828
                https://soundgas.com/product/1966-vo...t-pedal-oc-76/
                I'm still not 100% convinced which it is ...
                  http://www.bigmuffpage.com/The_Tonebender_Timeline.html
                  The Tone Bender Timeline
                  It's All Over Now
                    You're right. That's confusing. While the Vox page doesn't mention the Mk1.5, the article doesn't mention the V828. Maybe its different names for the same thing?
                    If not, it'snot clear to me what could be the difference or which one was first.
                    Judging from the components I think yours was built around 67/68.
                      Originally posted by vintagekiki View Post
                      I saw that but it refers (on page 3) to it being Italian made and there's no evidence to
                      mine being Italian ... my understanding is that Italian ones didn't come in
                      until about 1968 and yet all the rest of the evidence points to mine being
                      67 by my guess ...
                        I need to find a VOX specialist / specialist forum like I said but there doesn't seem to be one ...
                          You might be onto something with "different names for the same thing" ...
                          I'm leaning towards it being V828, that comes up much more frequently ...
                          http://effectsfreak.com/effect/vox/v..._case_1967-68/
                          If you look at the first "Additional seller photos for reference" on the left and press 'view',
                          that one has similar internal wiring to mine
                            The sequencing here places it after the Mk1.5 and indeed the Mk2
                            https://www.stompboxes.co.uk/History.html
                            ... but it doesn't name it as a V828
                            It also refers to it being Italian made apart from an early run ...
                            perhaps that what I have ... the switch in mine is clearly
                            labelled Made in England ...
                              Originally posted by drdanny View Post
                              It has SFT337 and SFT363e transistors ...
                              https://fuzzcentral.ssguitar.com/vox.php
                              The Vox ToneBender uses a SFT337 for Q1 and a SFT363E for Q2, while the ToneBender MKI is said to have used OC76 transistors for Q1 and Q2.
                              It's All Over Now
