Hi everyone,
I hope this will be a quick one for someone with experience working on tape echos:
I've been working for a while now on reviving a beat-up Echoplex EP3, with the main issue being a loss of the erase function.
A few days ago I finally did some checks on the record/erase head itself, and I might have found the problem: I measured resistance across the coils of the tape head, and while the recording side measures 62.5 ohm, the erase side measures OL, in and out of circuit.
Before I go ahead and try and find a replacement, could someone confirm that this means the tape head is dead, without a doubt?
A few points:
- I've attached a labeled layout of my Echoplex, and the schematic
- On point 15, I'm measuring only 0.44V (I think I remember reading it should be a lot higher)
- On point 17, I'm measuring 28V
- I'd love to open the tape head to check solder connections of the wires, but the assembly seems to be sealed
- I've checked all electrolytic capacitors, and swapped a few
- I've cleaned the tape heads with IPA, and recently reloaded the tape cartridge with NOS 8 track tape
Hope someone can help, finding the issue on the this machine has been driving me crazy!
ECHOPLEX_OWNER-SERVICE_MANUAL 29.pdf
A few points:
