Hello all!
I have been using a TRUETONE 1-Spot (9V 1,700 mA) + Daisy chain for a while and “tolerating” some high pitched noise coming from a EH MEMORY MAN with HAZARAI. I say tolerating, because even if I knew the noise would go away connecting the MEMORY MAN to a dedicated PSU I kept on using the Daisy Chain for simplicity (I also did the math and knew the noise shouldn’t be a current draw issue).
I have recently acquired another DELAY PEDAL, and ECHOPLEX EP103 and (particularly at our practice studio) then noise became unbearable (even with the MEMORY MAN not in the pedalboard). NOTE: I double checked with an identical pedal from a friend and got the same noise.
Sample of the noise attached as it plays through the amp (I see the main peak at 3,000 Hz and lower ones at 6,000 and 9,000)
I have been trying different Low Budget Isolated PSUs with multiple 9V 100 mA, a couple of 9V 500 mA and extra 12V and 18 V outputs. Particularly: Donner DP1 ($41) , AMUZIK ($32) and HIREE ($40)
Long story short, none of them worked. For the AMUZIK and the HIREE, if I had only the ECHOPLEX Pedal connected, the moment I connect any other pedal to the PSU the noise starts.
The best result I got was with the DONNER DP1 to which I could have connected the ECHOPLEX (to the 500 mA output), a Behringer Tremolo (30 mA), Holy Grail Reverb (105 mA), TC Electronics Viscous Vibe (100 mA), Rat Distortion (? mA) and Selah Love V3 Overdrive (100 mA)… every single one of them to an isolated 9V 100 mA output. But whenever I would connect the EH Micro POG (180 mA) to either a 100 or 500 mA output the noise would be back.
I’ve opened the Donner and AMUZIK up (not the HIREE but the inside is shown on the AMAZON photos) and the DONNER seemed to have more electrolytic capacitors (22x 100 uF 25 V + 2x 220 uF 25 V) than the AMUZIK (14x 220 uF 25V) which I think would account for better filtering. Both have a 18V 1,000 mA PSU plugged to the wall.
AMUZIK
DONNER
I still can return all these PSUs and start thinking on spending the big bucks but I have the hope that maybe the solution is as simple as increasing the value and quality of the capacitors on the DONNER (and of course voiding the warranty and al chance of returning it if it doesn’t work)
What do you guys think?
Thanks in advance!
AMUZIK
DONNER
Thanks in advance!
