I have several questions. First, if I want to convert (eliminate) from 9v battery to 9v power receptacle, do I just simply clip the red and black leads to the battery and solder them to an appropriate 9v dc receptacle? Second, when I opened the case, I found 2 wires that were't connected. One has a loop that most likely connected to one of the removed case screws but I'm not sure. The other wire was near the dpdt so as tempted as I am to connect it to the only empty contact, I'm hoping someone here can tell me where it actually belongs. I can't find any images online that could help and none of the schematics I've seen show wiring to the dpdt.
Big Muff Pi Green Russian Pedal Wiring Questions
http://www.bigmuffpage.com/Big_Muff_Pi_versions_schematics_part3.html
https://tetsuoelectronics.wordpress.com/2011/01/23/green-big-muff-new-switch-and-power-jack/
https://www.element14.com/community/blogs/andybetts/2018/09/07/sovtek-green-russian-big-muff-pi-clone-commission 1)
http://www.kitrae.net/music/big_muff_history2B.html 2)
3)
It's All Over Now
- Likes 1
Originally posted by Perkinsman View PostYes, I've seen several of those sites but I can't specifically find the wiring diagram to the dpdt in my picture.
This Premier Guitar one shows it clearly:
The left one shows:
Center lug goes to preamp input C15-R26-C1 node
It alternatively switches EITHER to input Jack hot lug to get guitar sound OR to Ground to minimize noise.
The right one shows:
Center lug goes to output jack hot lug
It alternatively switches EITHER to Level pot wiper to get distorted sound OR input Jack hot lug through a piece of wire.
Classic True Bypass.
So with switches UP (as shown) the path is : Input Jack > switch > Distortion PCB > switch > output jack.
With switches DOWN: Input Jack > switch > wire > switch > output jackJuan Manuel Fahey
- Likes 1
