A friend asked me to help a fellow guitar player with his problem concerning his wha. Its a Crybaby gcb-95 wah. I have reached the end of troubleshooting ideas, so I am asking for help. The problem is the wha makes a loud pop when switching to effect mode. Simple right, not so fast.
This wha was converted to true bypass by someone else. So I checked the wiring. Simple true bypass with a jumper across two terminals. The buffer is still being used. The wiring checks out. Other mods done, Fasel inductor, resistor across inductor increased to 39K and midrange resistor increased to 2.2K. Wha sounds great except for the pop, only when engaging the effect. No pop when going back to bypass mode.
What have I done. Changed the true bypass wiring on the switch to short the input when in bypass. Still pops. Added 1 meg resistor on input jack, still pops. Measured all voltages, no dc on the switch or pot. I changed out the switch, why not. Other things I have checked. Re-soldered some joints. I powered the wah from three different sources, my pedal board supply, separate adapter and battery.
On my supply, power up in bypass mode, engage and pop. Go back to bypass and engage, no pop. Wait 90 seconds before repeating and pop.
Same on the adapter. On battery, a pop only on first engage. Does not pop again until power down, up and engage, one time again.
i measured the 9V supply on the board while switching and no change in voltage. FYI, meter is Fluke 8060A. It looks like a power problem but I cant find it. So I am asking for help. Open to all offers. Thanks for stopping by.
